Super Farm 70D
Richard
12-29-2003 11:18:34
I am wanting to pull a 70d in the Super Farm 5500#, 6500# and maybe the 7500# classes. I know I can get one that light. My question has to do with power to gear ratio. I would like to be able to use second in the 5500# if I needed or wanted to. I do not want a fortune wrapped up in the tractor. Any help will be appriciated.
Thanks
Jerry @ Pullsite.com
01-03-2004 10:52:25
 Re: Super Farm 70D in reply to Richard, 12-29-2003 11:18:34
My son Andrew pulling a 70D. Has 16.9 X 38's
and is in 1st gear. Hit the 3mph horn
twice..
JerryB
12-29-2003 16:31:59
Richard,you need to talk to Bob from Triple G Service(John Deere parts / salvage yard).He bought a lightened up John Deere 830 from somewhere in PA ,and spent the last year or so making it lighter and doing a lot of engine work and fuel system work .It now weights 6,350 lbs.with a driver ,and I know at the NY JohnDeere Expo last summer he ran Forth gear in the 7,500 lb. modified class. I'm sure he would be helpful.The phone number there is 1-888-720-0830.
DCPULLER
12-29-2003 14:53:05
put that famous creeper gear in it and a 5HP briggs and stratton will give you all the power you need on a power track . course its like wacthing paint dry
johndeere_john
12-29-2003 19:40:59
 Re: Re: Super Farm 70D in reply to DCPULLER, 12-29-2003 14:53:05
The 70 doesnt have a creeper gear, uses the same tans and rear end the G uses Jon
Richard
12-29-2003 15:03:20
I was being serious. The idea of the 70 was to get rid of the creeper gear.
Jack
12-29-2003 14:46:22
Unless you go with pressed steel wheels you won't be able to get much less than 6500lb.Second gear is gonna be tough to handle on a 70 cause 1st is fairly fast by itself.Takes a lot of hp to run a 70 in second gear short of stroking it $$$$$$.Good luck to you,Jack(TN).
Tyler Neff
12-29-2003 19:49:10
 Re: Re: Super Farm 70D in reply to Jack, 12-29-2003 14:46:22
A 70D will pull just fine in second gear at 2.5 mph. 1st gear is much slower. A 70G uses the same gearing as a G.
70 puller
12-30-2003 08:58:47
 Re: Re: Re: Super Farm 70D in reply to Tyler Neff, 12-29-2003 19:49:10
The 70d has the same gearing as the 70g. First gear is 2.5 mph. and second is 3.5 mph.
Tyler Neff
12-30-2003 19:41:35
 Re: Re: Re: Re: Super Farm 70D in reply to 70 puller, 12-30-2003 08:58:47
A 70d has a slower 1st gear than a 70g . Check yourself.
70 puller
01-01-2004 08:25:09
 Re: Re: Re: Re: Re: Super Farm 70D in reply to Tyler Neff, 12-30-2003 19:41:35
Have a 70d and it is fast just like the 70g and the g models
buickanddeere
12-30-2003 22:01:08
Both the 70 gas and 70 diesel have the fast 2.5mph 1st gear.
