WD Allis puller
Randy
12-26-2003 17:27:00
Does anyone have any info on setting a WD up for pulling? Not looking for competitive Just fun pulling at the local pulls. Thanks!!!!!
Allis Puller
12-27-2003 08:55:48
 Re: WD Allis puller in reply to Randy, 12-26-2003 17:27:00
WD's are already very competitive in a stock class, What would help the most is get rid of the stock two peice draw bar. Take that draw bar and use the straight peice and cut it off closer and drill a hole. If you don't want to touch the motor then I woud get a wider rims cuz the ones you have are most likely only 10" wide. The power adjust wheels off a D-17 work nice - they are 13" and match them with a good set of 13.6's or 14.9's if your rules allow. Then have fun.
Nick
12-31-2003 20:08:03
 Re: Re: WD Allis puller in reply to Allis Puller, 12-27-2003 08:55:48
Can you post a picture of your hitch setup? My stock hitch can't hold down my power. I have firestone 13.6 28s and the dyno says I have 56hp at 600 rpms. I get killed by the early styled JD A's and the farmall M's. I know I have more power than those tractors but they are so much heavier. The rules allow 15.5 tires but I don't think they make 15.5 by 28, am I wrong?
Agent Orange
12-26-2003 18:54:34
Send Email and I'll send pic of "just for fun puller". Been at it three years and still having a blast!
