Oliver 77 pulling engine
Jeff
12-24-2003 03:33:34
I would like to build a pulling engine for Class II. I have pulled it stock and had a lot of fun in the stock classes but I need more power in Class II.
I purchased a set of 3 3/4 inch pistons from Korves but I haven't used them. Some have suggested Super 88 sleeves bored to 4 inches with a bored block. Also a Super 77 crank ofset ground to stroke the motor to 4 inches for about 300 cubic inches total.
Others say use the stock crank, 3 3/4 inch pistons, and concentrate on the head. This gives about 250 cubic inches. I plan on stock rpm or 5 to 10 percent over.
Can larger valves be installed? How much to mill the head for higher compression? Where to send the head? What to do to the carb and to whom to send it? Different intake manifold? Any guidance would be appreciated.
770
12-25-2003 06:22:11
 Re: Oliver 77 pulling engine in reply to Jeff, 12-24-2003 03:33:34
3-3/4" pistons in mine. Head work(shaved,ported, polished) carb work and some manifold porting puts me at about 65 horse. Whats nice is that the tractor is still "useable". If you want more horses, Then bore & stroke but 70 horse w/o stroking is relatively easy to do....
Keddano
12-24-2003 18:20:38
Jeff, Since you have the overbore kit,I would use it(unless money's no problem),Then concentrate on head and intake,& carb.The head can be cut down 1/8" to bring up the compression(making it about 10:1).I had my shop stuff in S.S. neckdown small block chevy intake valves(as big as they can),hog the bowls out and port it to match a cut-down 1650 intake,get the big stock carb to match(you'll need to cut about 10MM off the outside runners,make a jig plate to match the old 77 intake),then plane the exhaust down to match the 77 exhaust manifold.The block will have to have the ear(hump) ground down to clear the carb. Then get a good cam.(Contact Brad M.) This should give you a set-up that will do well in Div 2. If money is no object go to a super 77 crank and stroke,go to 4" bore(311 C.I.) wind it up and have fun Stomping!
dan
12-24-2003 17:12:07
a super 77 intake will give you larger runners and alarger carb flange. milling the head for more compression is a waste of time, money, and material that you need when you do make compression. boring the block for 88 sleeves and boring them to 4 inch gives lots of options for pistons. stroke is where you get your torque, but it can get costly. how big do you want to go?
ollie puller too!!
12-24-2003 07:45:48
It depends on what the checkbook says you can afford, I would go with 100thousands on shaving head and bigger valves, use a super 77 or 770 intake for more air. Also port and polish head, have fun.
Jon
12-24-2003 08:26:17
 Re: Re: Oliver 77 pulling engine in reply to ollie puller too!!, 12-24-2003 07:45:48
We took a Oliver 1650 gas intake manifold cut it in 4 places to shorten it then weld it back together. We werent really trying to get a bigger intake we were doing it so we could run our big Zeinith carb. Only problem was the carb was so big you had to take it off to check the oil.
