Need to slow down My John Deere A
matt
12-22-2003 09:38:40
I am starting to pull my '48 John Deere A and it is way to fast. I currently have the two stick setup and I am looking for a later single stick six speed transmission. My question is can I look at any other tractors for the parts that I need such as a 60. I also need to know the years that my apply. Thanks
FB
12-23-2003 10:13:47
 Re: Need to slow down My John Deere A in reply to matt, 12-22-2003 09:38:40
You could just get a smaller tire heighth wise. Probably would be ALOT easier
520-LP
12-22-2003 18:19:05
You can put the first reduction gear and complete pulley assembly out of an A with a single shifter will slow you down a 1/4 mile per hr.
mike
12-22-2003 15:23:07
why not do what the pulleres around here do
any time there pullin
sounds like
they take one plug wire off
that outta slow it down
JDBert
12-22-2003 11:11:44
Matt, You need the creeper gear set up like in the 51' and later A's (588,000 and up)or a 60 which is the same. I know people have put the gears for the creeper in earlier modles. I've never done it, so as to what you need I cant tell you, but it can be done.
