Epoxy
Allis
12-18-2003 15:36:27
Does anyone know where to get an epoxy block filler and what brand? I have heard it will transfer heat better than hardblock and will not crack over time
olli-man
12-19-2003 16:39:21
 Re: Epoxy in reply to Allis, 12-18-2003 15:36:27
look up Devcon acrylic on the net Devcon is thhe brand name and they have many products for many different uses they might have what you need.
ChadS
12-18-2003 15:40:21
Fiberglass resin works well too. If mixed right,, won't crack,, but if it sets up too fast it will crack,, Just my 2 cents,, ChadS
Allis
12-18-2003 15:46:03
 Re: Re: Epoxy in reply to ChadS, 12-18-2003 15:40:21
Thank's I need to do something, block won't hold water and don't want to use anymore hard block
ChadS
12-18-2003 17:33:33
 Re: Re: Re: Epoxy in reply to Allis, 12-18-2003 15:46:03
It works,, just don't put too much hardener in it at once,, let it dry and set up slowly,, I let mine set up and dry for about 2 days,, ChadS
Allis
12-18-2003 17:58:11
 Re: Re: Re: Re: Epoxy in reply to ChadS, 12-18-2003 17:33:33
You used in the block? I have too fill it solid, no water. Will it work? What brand did you use?
ChadS
12-18-2003 18:34:07
 Re: Re: Re: Re: Re: Epoxy in reply to Allis, 12-18-2003 17:58:11
Yes, I did use it in the block. Any good fiberglass resin,, I will look at the brand name in the morning,,, ChadS
