WANTED 13.6X24 TIRES AND RIMS
N Puller
12-16-2003 21:14:45
NEED TWO 13.6X24 TIRES AND RIMS TO FIT 8N WITH 8 HOLE RIMS
Where you from?
12-18-2003 07:54:09
 Re: WANTED 13.6X24 TIRES AND RIMS in reply to N Puller, 12-16-2003 21:14:45
Where are you from? Are there a lot of pulls in your area?
N Puller
12-18-2003 16:19:20
 Re: Re: WANTED 13.6X24 TIRES AND RIMS in reply to Where you from?, 12-18-2003 07:54:09
TX.I PULL WITH THE TATPA AND ONLY 5 PULLS SCHEDULED FOR NEXT YEAR SHOULD BE MORE BEFORE THE SEASON STARTS I THINK THER WAS TEN OR MORE LAST YEAR.
ChadS
12-17-2003 04:29:11
I have a set of 16.9X 24 or 26,, BF Goodrich, 23 degreee bar. 8 bolt,, off of combine.. Don't know if that will help ya,, 90% tread. ChadS
N Puller
12-17-2003 06:34:22
 Re: Re: WANTED 13.6X24 TIRES AND RIMS in reply to ChadS, 12-17-2003 04:29:11
13.6X24 IS BIG AS I CAN GO I DIV 1 3100 3600 I HAVE 11.2X28 NOW LOOKING FOR WIDER TIRES AND RIMS
WITH THE SAME HEIGHT.13.6X24 MAKES 130 SQ" 12.4X28 MAKES 127 SQ" SHOULD I JUST GO WITH THEM?THANKS
NE Ind. Ford puller
12-17-2003 13:38:25
 Re: Re: Re: WANTED 13.6X24 TIRES AND RIMS in reply to N Puller, 12-17-2003 06:34:22
I'de stay with the 28's. Our 8-n has around 40 hp & thats about all the tire it needs. Think about traction in snow. Pulling is the same way. With a narrower tire in the light classes the tire tends to dig in better whereas the wider tire tends to just float. We run 12-28's on our 600 Ford also. We won the 3000# & the 3250# div. 2 classes with this set up at the NATPA pull on fri. at Wauseon Oh. over thanksgiving.
Another n Puller
12-16-2003 22:32:09
Where you located? Could you use 14-9s?
