weld-on hubs question
marty
12-16-2003 20:37:12
How thick is everyone making their weld-on hubs?I was thinking of using 1"-does this sound allright? It is for a 7,000 lb tractor.
farmall
12-17-2003 13:08:33
 Re: weld-on hubs question in reply to marty, 12-16-2003 20:37:12
I use 1/2" thick weld-on hubs in the 4500 to 6500 classes. They work well. Make sure the clubs and classes you pull in allow them. When welding be sure to wrap wet rags around seal area to prevent overheating them. Use four gussets on each plate to reinforce them. Be sure to weld both gussets and plate on both sides with good penatration. Use 70,000+ rod and you will never brake them loose.
FF
12-17-2003 09:46:31
What about if something breaks in the final drive and you have a weld on hub? Seems like you will have to cut it off to make repairs. Just posing the question.
FF
JDGnut
12-17-2003 15:55:07
 Re: Re: weld-on hubs question in reply to FF, 12-17-2003 09:46:31
It depends on the tractor.. on a JD.. the only thing that installs from the outside is the felt seal and ring... and with some work I think you can work it ovr the sealing collar... All the bearings go on the axle from the inside out... JDGnut
FF
12-18-2003 08:04:14
 Re: Re: Re: weld-on hubs question in reply to JDGnut, 12-17-2003 15:55:07
Farmalls are not so easy. The inner bearing comes off from the end of the axle opposite of the hub. The outer bearing must be slid off of the axle past where the hub would be welded on. Seals are the same way. Thanks for the information JDnut.
FF
ChadS
12-17-2003 04:38:04
1 inch will be just fine. On our 3500lb tractor,, we used 1/2 inch. ChadS
The Swami
12-18-2003 13:00:05
 Re: Re: weld-on hubs question in reply to ChadS, 12-17-2003 04:38:04
What model tractor are these hubs going on Marty???
