Farmall M front end question
Farmall puller
12-13-2003 20:16:53
Has any one lightened the wish bone on the front end on a M farmall. I have seen some that looks like there is just a pipe that holds the gear box up.I was just wondering if you could cut the two cast pieces that holds the gear box up and just weld a piece of pipe straight up to the gear box. I done have a light lower bolster and aluminum wheels just trying to lose some more weight off the front end.any advice would be appreciated.
FB
12-14-2003 09:26:10
 Re: Farmall M front end question in reply to Farmall puller, 12-13-2003 20:16:53
yes, it can be bone but most cut the entire wishbone out and a new one out of square tubing...both the middle and the two outside arches
Farmall puller
12-14-2003 09:47:52
 Re: Re: Farmall M front end question in reply to FB, 12-14-2003 09:26:10
Do I need to use cast metal to weld back to the gear box and the lower cast peice that bolts in the frame or can i use something else.
ChadS
12-14-2003 14:19:38
 Re: Re: Re: Farmall M front end question in reply to Farmall puller, 12-14-2003 09:47:52
I may be wrong,, but Would a 560 front end work on the M? If so,, a little steering shaft relocation and lose a lot of weight,, On my 460H, a 460 frontend will bolt into the H,, have not done this yet,, but have measured it,, Hope this helps,, CHadS
