18.4-38 Gearing
Chuck
12-12-2003 17:16:39
I have a good 4-mph gear at stock rpm on 15.5-38 but thinking about 18.4-38 or 16.9-38 how mutch ground speed will I pick up? Thanks
Dan
12-12-2003 23:04:18
 Re: 18.4-38 Gearing in reply to Chuck, 12-12-2003 17:16:39
We have a wc that we ran 15.5 and then went to 16.9 X 38. We had to drop a gear because the speed changed that much.2nd gear with 16.9 is as fast as 3rd with the 15.5.
Mike Aylward
12-12-2003 19:16:54
Chuck, this will vary somewhat if you are going to run a different brand of tire than what you are now running but if you stay within brands and types of tires the 16.9's will gain 6-7% and the 18.4's will gain you 12-13% in speed over your 15.5's. These percentages are approximate and will vary with rim width, depth of tread and other factors, but this will give you an idea. Mike
Chuck
12-12-2003 19:36:45
 Re: Re: 18.4-38 Gearing in reply to Mike Aylward, 12-12-2003 19:16:54
Mike thank you I went off of firestones tire book and we are thinking the same way 14.9x38 =3%, 18.4x34=4%, 16.9x38=8%,18.4x38=12% increase in speed But sometimes I don't think to well by myself Thank's for the ansewer back Chuck
TimC
12-12-2003 18:58:44
Don't know the answer but you will need plenty of torque to keep from choking it.
