tire question
joe
12-12-2003 09:38:46
I have a farmall M that I pull in 5500-6500 pound class. I have 15.5-38 tires and have the hitch as high and short as allowed. I spin out in first and second gear and dont have enough power in third. if I go to 18.4 38 will it give me more traction or less? the foot print will be bigger but the weight per square in will be less
Jim M
12-14-2003 00:44:40
 Re: tire question in reply to joe, 12-12-2003 09:38:46
What is the frontend doing? Does it come up at all? If it does not come up lighten up the front end or lengthen your hook point to transfer more weight from the fron to the rear tires.
joe
12-14-2003 06:20:52
 Re: Re: tire question in reply to Jim M, 12-14-2003 00:44:40
I have a 100# pound weight on the front and it stays on the ground until the last few feet of the pull and the comes up and the spins out
Pulling Prodigy
12-14-2003 12:24:01
 Re: Re: Re: tire question in reply to joe, 12-14-2003 06:20:52
is it spinning out when it hits the wheely bars?
ubtractorguy
12-12-2003 23:44:51
18.4 38's are really going to gear you up -have seen 18.4 34's on hot M's around here.
