RPM on an 88
Jerry B
12-11-2003 06:03:17
What is considered the safe upper limit on these 6 inch stroke Oliver 88's? I was thinking about 2500 or so, or that be considered too slow?
TimC
12-11-2003 06:28:29
 Re: RPM on an 88 in reply to Jerry B, 12-11-2003 06:03:17
The reliability of the flywheel is one thing to consider. The other is the weight of the pistons and rods. Rods breaking at higher RPMs is due to the g forces on the exhaust stroke. The rods seperate as it goes across TDC. Light weight forged pistons and aftermarket rods are capable of much higher piston speeds. Billet cranks also up the limit on RPMs. Long rods also allow the piston to slow down and speed up around TDC at a slower rate than short rods.
3000+ is safe for a well designed motor. 3500 would also be safe in my opinion.
