Who sells the foam to put in the rear end
Jon
12-11-2003 04:13:44
Who sells the foam to put in the rear end of your pulling tractor.
deadeye
12-13-2003 06:45:18
 Re: Who sells the foam to put in the rear end in reply to Jon, 12-11-2003 04:13:44
Just like putting a brick in your bathroom stool tank to displace the water. Takes up space.---deadeye
JDGnut
12-12-2003 05:57:31
If you are worried about the foam coming lose.. cover the foam with fiberglass... Itchy.. but it works... JDGnut
Brandon
12-11-2003 18:10:57
I'll admit I'm not much of a puller and I don't know much, but this has got my curiousity...Why would someone put foam in their rear end? Obviously not for weight?
Thanks
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
AZ Jack
12-11-2003 18:25:31
 Re: Re: Who sells the foam to put in the rear end in reply to Brandon, 12-11-2003 18:10:57
I am with you Brandon-what does the foam do-surely not a lubricant?
PB
12-11-2003 19:07:47
 Re: Re: Re: Who sells the foam to put in the rear in reply to AZ Jack, 12-11-2003 18:25:31
It is to save weight. Gear oil is kinda heavy, so the foam is used to displace the oil in the open areas. The oil can be up to the proper level while using less.
Neil
12-11-2003 19:04:40
The foam is put in the rearend to fill space so that you can put less oil in and still keep the gears in an oil bath. The foam weighs less than the oil that would otherwise be there, which allows making lower weight classes.
Dave N
12-11-2003 16:21:49
Just use the expanding foam that they sell at home improvement stores one brand is called Great Stuff
John B.
12-11-2003 04:33:43
The foam is the expanding type you can buy at any stores that sell home improvement products. Wal Mart, Lowes, ect.It will stick to any clean, dry surface. Apply, let it expand & dry then trim out any excess.
muddrive
12-12-2003 04:30:36
 Re: Re: Who sells the foam to put in the rear end in reply to John B., 12-11-2003 04:33:43
A couple of good plastic jugs that you can close glued to the bottom of the rear works well also - I have seen foam come apart .
