WD45 Pulling tires?
Rod
12-10-2003 17:22:11
What would be the best pulling tires for this tractor,pulling in stock class? 14.9-38(64inches tall) or 16.9-28 (54 inches tall)
Which tire would need the most power to turn them?
Farmall Daddy
12-11-2003 07:12:15
 Re: WD45 Pulling tires? in reply to Rod, 12-10-2003 17:22:11
If you run the 38's, then your ground speed will be faster and in return it will need more power to turn them as you go down the track. If you have the horsepower, go with the 38's because they will give you the speed to get through the soft areas. If not, go with the 28's. Your speed will be lower with these, but you won't sacrifice needed power. As for width, you would have to go with your rules, and how much power that you have. Good luck!!
