PROBLEM WHILE BUILDING ENGINE
JOE
12-10-2003 15:05:46
I am building an oliver engine with big bore and stroke and am wondering what you guys are doing when the rod comes around and hits the camshaft? Are you grinding material off of the rod or the cam? I have already had my rods shot peened so I dont think that it would be wise to grind on them. Just wanted to see what other people were doing. I probably dont have to shave off 1/8 inch of material to make it clear. Thanks in advance.
TimC
12-10-2003 16:29:03
 Re: PROBLEM WHILE BUILDING ENGINE in reply to JOE, 12-10-2003 15:05:46
Farmall is right. Butterfly the cam. To keep from installing and uninstalling the cam a dozen times to get it cleared do the first one then you can figure where all the others will hit. You can do two the hard way and you will see the pattern. for example you may be 45 degrees past the top of every intake lobe. To feel safe about it you may want to do them one at a time. A little belt sanding on the rods is not going to be detrimental unless you are running a lot of stroke with short rods. It also depend on the rods which you didn't mention how beefy they are.
You might also use cap screws from arp or some place if it is just around the bolt head that is going to hit. Grinding both sides of the cam will probably be the most cut and dry process.
farmall
12-10-2003 15:15:21
Camshafts on Oliver's are cast iron anf therefore weak. Don't go thinner than .550 in thickness (machine flat's on cam) use stock valve springs to avoid cam deflection, eventualy breaking cam.
Hope this helps
