super 88 needing more
john b.
12-10-2003 13:29:02
I have a super 88 pulling in div. 2 wanting to move in hp.I do not know a hole lot about oliver what are some combination pistion,crank,and cam.
The tractor does have head work to it and my rules will let me run open rpm.Will do the work my self will grin not alot. thanks
TimC
12-10-2003 20:44:48
 Re: super 88 needing more in reply to john b., 12-10-2003 13:29:02
1100 massey head helps.
A.P.
12-10-2003 16:15:07
I would set it up with a 4 3/8" bore. You can bigger but will definiely need to fill the block with hard block. You may want to do it with the 4 3/8" bore if you are serious about running some rpm. Give Brad Maibach a call at Maibach's Tractor in Creston, Ohio. He can give you some good recommendations for combinations and parts sources.
Good Luck
Charlie
12-15-2003 00:55:24
 Re: Re: super 88 needing more in reply to A.P., 12-10-2003 16:15:07
All you may need if you want to do your self is stroke your crank. I have the rods to do so for you but will need the crank off set ground and pistons shaved. Also a 1600 manifold and carb help. Call me 1-585-335-9274 7-7pm EST.
