RE JD G Problem
Jonathan
12-10-2003 13:04:55
I posted a while back about my G dieing when it was under load. Well it wasn't fuel or electrical, I tore it down again and found that when the people that bored out the block for me they only gave me a 9 thou clearance for the pistons so what was happening is evertime the tractor started to gain temp. it would siese up in the cylinder. To make along story short it means a rebore again. lots of fun.
a puller
12-10-2003 16:28:14
 Re: RE JD G Problem in reply to Jonathan, 12-10-2003 13:04:55
if you take a good hone, you could prolly get that out to 15....don't know how perfectly round it would be, but if its a good hone, then the rings should re-seal.....maybe this will help? any other sudgestions....?
big jugs
12-10-2003 17:37:27
 Re: Re: RE JD G Problem in reply to a puller, 12-10-2003 16:28:14
Hey, I had the same problem a few years ago. We were able to have it honed out to enough clearance. Forgot all about it till you mentioned it. good luck!
