Mixing diesel fuel gas for pulling
puller
10-08-2001 14:16:48
New to this pulling thing, so be KIND!!! Someone said you could mix gas and diesel fuel in diesel tractor's for more power--can you and if so what is the mixture and will it harm anything? Any suggestion's for more bang without going into it (not ready to rebuild anything yet, just having fun playing and looking for possible quick fixes).
Sid
10-14-2001 07:51:11
 Re: mixing diesel fuel gas for pulling in reply to puller, 10-08-2001 14:16:48
Correction on the intake fuel it WONT be so hot
Sid
10-14-2001 07:49:40
Mix at 5cc per gallon will stop preignition and the intake fuel will be so hot. Try it on a pto dyno and you will be amazed with the low end lugging power
tim
10-18-2001 07:08:58
 Re: Re: mixing diesel fuel gas for pulling in reply to Sid , 10-14-2001 07:49:40
hey Sid explain that to me. mixing gas with diesel fuel to run in a diesel will make more HP in the diesel engine What is your mixture so i get this right, gas ratio to diesel fuel. what kind of performance diffence are there, more rpm, torque? does it hurt the engine? tim
puller
10-14-2001 16:10:46
What do you mean by cc--how much is that in 1/2 pint/pint etc.
Dave
10-10-2001 03:55:48
my brother enlaw & I use to use castol oil..not the motor oil kind,,the kind mom use to give you ..We put a 1/2 pint to a tank of gas in are WD45 AC when we were pulling,,and we could tell a diff.. It made the motor run harder...
Bryon
10-09-2001 08:30:46
One of the guys we pull with is building a Super Stock tractor, he said they mix 50/50 gas/diesel and add a quart of 2-cycle oil for lubrication. He suggested we mix 5 gal. diesel, 1/2 quart gas, and a small can for 2-cycle for the two 560D we pull. Did it for one pull, but it was hard to tell a difference, several other factors.
thetractorguy
10-09-2001 03:31:31
you can inject propane into the intake,but thats illegal any where i pull
Dael13
10-09-2001 12:51:05
 Re: Re: mixing diesel fuel gas for pulling in reply to thetractorguy, 10-09-2001 03:31:31
Now hold on there ,I thought propane was one of the [LEGAL] fuels.i did not read anything about not using it in a diesel.
troy
10-08-2001 19:11:32
I've never tried it myself but what I was told was not more than 1 qt. per gallon. good luck
Pete
10-08-2001 18:04:25
Puller, Maybe!?!?!? Ya'd really hafta know your stuff, cause gas combusts at much less pressure(which is what causes a dsl. engine to combust,) than dsl. fuel.It would seem that if combustion took place earlier in the stroke (while the piston is further from TDC) less power would result on the down stroke. Like I said, just my theory. Also, dsl. fuel has lubricants in it that lubricate the injector pump, gas has none, and tends to break down lubricants, which seems that it would mean less or no pump lubrication. Pete
