f30
phil
12-06-2003 16:45:39
is the engine out of a 1020 the same as the f30 engine. looks like you should just change the bell housing
dean
12-07-2003 17:05:38
 Re: f30 in reply to phil, 12-06-2003 16:45:39
always thought f-20 and 10-20 were same and f-30 and 15-30 or 22-36 were same...we have several of both but have never transplanted...there is a narrow tread f-20 running here in central mo that is very competitive think he is running jd 4020 pistons in it
Bigred
12-07-2003 06:09:12
The 10-20 block is about as close to a bolt in replacement as you can get! Same bore and stroke but less compression ratio. Cam timing is slightly different,but using the f30 head on the 10-20 cam will yeild more lift due to the difference in rocker arm ratio. There may be a few untapped accessory holes in the 10-20 block, just depends on what year it is. A very overlooked engine for pulling. We,ve built a number of these engines to 701 ci.
phil
12-07-2003 16:21:12
 Re: Re: f30 in reply to Bigred, 12-07-2003 06:09:12
thanks bigred for your help if you would like to give me some pointers that would be great. this is the frist red tractor we have done so this is all new here thanks again
greenweenie
12-06-2003 16:52:40
You know it, Phil. Are you wanting to build an F30 or 1020? I've heard there is a pretty good 1020 out there, some where. Do you know of anyone that has done anything with an F 20? I've never seen one strong enough to start a sled.
Oklahomatractorrebuilder
12-06-2003 21:28:49
 Re: Re: f30 in reply to greenweenie, 12-06-2003 16:52:40
I am not sure about now but there will be a f-20 able to pull sled next spring. In process of putting a IHC 549 V-8 gas truck engine in a f-20 chassis. Tim
miss'b'havin
12-09-2003 06:06:44
 Re: Re: Re: f30 in reply to Oklahomatractorrebuilder, 12-06-2003 21:28:49
I'm sorry, I thought this forum was about antique and classic tractor pulling... I guess I was mistaken. If you have to put a V8 in an antique tractor frame, just so you can run with the big boys, that's your business, but it sounds like you don't have what it takes to make a stock block hang on the track.
12-09-2003 18:38:45
 Re: Re: Re: Re: f30 in reply to miss'b'havin, 12-09-2003 06:06:44
The only reason for putting the V-8 in the stock tractor chassis is I have it. I already pull a stock F-20, stock Regular, stock Super M and a stock MM UTS. And working on a W-6 and a B Farmall. But at our club pulls they always have a friend who shows up and puts on a show with a 4430 JD just for fun. As long as I had a extra F-20 here, Why not have some fun with it. Plus it shore will sound good with 4 inch straights and propane burpers. Tim
ChadS
12-06-2003 17:17:01
Years back,, there was a F-20 out of Illinois that pulled the sled at 4500,5000,5500 in second gear,, Don't know what was done to it,, had to pull it to start it. Seen it in Columbus Super pull. ChadS
phil
12-06-2003 17:33:36
 Re: Re: Re: f30 in reply to ChadS, 12-06-2003 17:17:01
f30 has a crack block.we know where a 1020 block is didnt know if they where the same. wanting to build div 2 puller out of f30
Mike Rooker
12-06-2003 21:09:20
 Re: Re: Re: Re: f30 in reply to phil, 12-06-2003 17:33:36
f-30 and 10-20 are not the same f-30 is biger at the bell housing f-20 and a 10-20 should work?
reddog
12-07-2003 20:13:03
 Re: Re: Re: Re: Re: f30 in reply to Mike Rooker, 12-06-2003 21:09:20
I need a set of rear hubs for a F30. Anybody got any????
