Power Block for a 2 cyclinder John Deere
Dan
12-06-2003 16:26:30
First I would like to thank all of you who have patiently tried to answer my questions as this is all new to me. It sounds like I can use a power block in my JD 70, my question now is, are their 2 different power blocks, I've heard of a 6-1/2 and a 7" sold by TSC. I have emailed several tractor places about the power block and as yet have not received any responses. Are there only used ones or can you purchase new ones, as it looks like TSC no longer sells them. Any information is appreciated.
Thanks Dan
greenweenie
12-06-2003 16:33:13
 Re: Power Block for a 2 cyclinder John Deere in reply to Dan, 12-06-2003 16:26:30
Dan-You must think power blocks grow on trees. If you are lucky enough to ever find one, you are probably going to have to put another mortgage on your house to pay for it. If you are just trying to boost some power and not get nuts, you ought to consider a half to a three quarter inch stroke and keep your stock pistons and block. I will guarantee you, you'll blow any body off with a stock stroke and a power block, off into the weeds.
Dan
12-06-2003 17:21:58
 Re: Re: Power Block for a 2 cyclinder John Deere in reply to greenweenie, 12-06-2003 16:33:13
Ok, you convinced me. Now,you say I can use my stock block and pistons but do I get a different crank or do I have mine off set ground and what rods would I use for this combination? What is the most stroke I can go without getting into major clearencing, 1/2", 3/4", 1", or more?
Thanks again Dan
Paul
12-07-2003 19:57:14
 Re: Re: Re: Power Block for a 2 cyclinder John Dee in reply to Dan, 12-06-2003 17:21:58
1.25" should not be too hard with A rods I run this in a G. some cam and main case clearance work not too bad You might also consider an all fuel block 6.125"(vs 5.875" gas) block then bore .125 with G piston. I have one all fuel block if interested.Paul
Dan
12-08-2003 02:49:23
 Re: Re: Re: Re: Power Block for a 2 cyclinder John in reply to Paul, 12-07-2003 19:57:14
Hello Paul Yes I may be interesed in your G all fuel block,How much would you be aksing for it and about where are you located or what would the shipping be to 49091.
Can I use the G all fuel block and also stroke it to 1.25
Thanks Dan
paul
12-08-2003 08:02:51
 Re: Re: Re: Re: Re: Power Block for a 2 cyclinder in reply to Dan, 12-08-2003 02:49:23
Send me an email @ [email protected] or call me tonight 605-685-6323 would sell block for$250 freight I am guessing at$100-150 Paul
greenweenie
12-06-2003 18:54:01
I suggest you either call TNT machine shop in Polo, MO or Keith Merfield. I think with 1/2 or 3/4 inches of stroke, you should be able to use your stock rods with very little clearancing. You can find TNT's number in the Hook magazine.
