mm head question
dave
12-06-2003 13:33:35
we have a ub with 500 cu. in. running 4231 heads w/ stock valves. we've been told not to add bigger valves then we were told yes put in bigger valves and have head worked on. whats everyones opinion? and whats everyones opinion on roller rockers worth the expense or not?
BUD BARENIE
12-11-2003 15:13:28
 Re: mm head question in reply to dave, 12-06-2003 13:33:35
4231 HEAD IS A VERY GOOD CHOICE, BUT YOUR COMPRESSION RATIO WILL BE VERY HIGH. YOU WON'T BE ABLE TO RUN PUMP GAS!!! CHECK WITH THE MACHINE SHOP, HOW MUCH OF THE VALVE IS SHROUDED IN THE HEAD !!!! GET RID OF THE VALVE GUIDE IN THE RUNNER IF THERE IS AN EXTENSION. NEED TO RUN A 670 DIESEL MANIFOLD, AND A COLD INTAKE MANIFOLD. CHANGE THE GOVENOR TO A GVI TYPE. SOUND'S LIKE A GOOD WELTERS SET UP!!! IT'S GOT TO BREATH THRU THE CARB, PAY CLOSE ATTENTION TO MANIFOLDS, ASK THE MACHINE SHOP THE VALUE OF BIGGER VALVES. EVERYTHING NEEDS TO MATCH TO ACHIEVE BANG-VERSES=BUCK!!!
GOOD LUCK THAT'S AN INTENSE PIECE OF EQUIPMENT
Mopower
12-09-2003 06:16:12
All depends on what RPM range and what classes you'll use it for.
a puller
12-07-2003 17:49:51
alot of people do put in bigger valves, might be worth it...:S
