DC Case pullers, I need some GOOD advice
wanna pull a ca
12-05-2003 12:30:51
I want to build a DC for a Hot Farm class, no rpm limits, would like to keep cubes 350 to 400 at the very most, don't want to stroke it, has anyone put a newer blocke, 830, 870, etc in a DC yet? Any ideas, suggestions, or general BS is of course appreciated, thanks.
laipuller45
12-05-2003 22:21:45
 Re: DC Case pullers, I need some GOOD advice in reply to wanna pull a case, 12-05-2003 12:30:51
dc is a good one to build, but lb 4 lb, you can make more hp out of an la, run almost as light as a dc, and gobs more torque. if you want a cas puller, that ma be an option to consider
CASEPOWER
12-05-2003 13:30:43
Theres not any block that will interchange that I know of. It would be hard to pass a later block off as original. You can go 4-1/2 to get your 350 cubes. You would be better off going 4-5/8 and using LA sleeves. Either way the more $$ the better your gonna pull. It wouldn't be hard to do what you want. Be sure and have it all ballanced if your gonna turn a bunch of RPMs.
ChadS
12-05-2003 20:43:16
 Re: Re: DC Case pullers, I need some GOOD advice in reply to CASEPOWER, 12-05-2003 13:30:43
DCTOM can tell you what you need to know,, He is MR.CASE,, in this area,, very respected puller, and collector,, If I am not mistaken,, but could be,, he had a DC3 that had a combine engine in it,, what model,, I don't know,, you can find him in the case forum,, very nice guy,, CHadS
CASEPOWER
12-06-2003 08:40:57
 Re: Re: Re: DC Case pullers, I need some GOOD advi in reply to ChadS, 12-05-2003 20:43:16
That was a VAC he put a 201 combine engine in. I don't believe that he put a combine engine in a DC. The only engine that would be close is a 400 case engine.
RoyG
12-08-2003 16:55:06
 Re: Re: Re: Re: DC Case pullers, I need some GOOD in reply to CASEPOWER, 12-06-2003 08:40:57
SP 12 used a DO engine - came with 4 inch alum pistons i think after 42
wanna pull a case
12-05-2003 20:53:15
Hey chad, I see were both up late tonight, LOL< thanks for the tip, I'll check it out.
