Boring M block
Smitty
12-05-2003 07:31:25
Has anybody ever bored a standard 248 M block to 4.375? Can it be done without sleeves?
WIld Horses
12-05-2003 10:25:51
 Re: Boring M block in reply to Smitty, 12-05-2003 07:31:25
No. My M is running 4 5/16 Chevy pistons. The Arnold's guy hit water when he tried to open the bores. He wound up putting sleeves in. What pistons are you using? I had to have the rods lengthened about 15/16 to get the piston top flush with the deck of the block.
Smitty
12-05-2003 11:00:03
 Re: Re: Boring M block in reply to WIld Horses, 12-05-2003 10:25:51
I was just wondering. I know M&W used to make a 4 1/4 kit with sleeves. I figured you'd have to bore 4 3/8 to use a 4 1/4 sleeve. So you hit water at 4.310?
ChadS
12-05-2003 17:32:30
 Re: Re: Re: Boring M block in reply to Smitty, 12-05-2003 11:00:03
On the M block yes,, the 450 block you would have no trouble taking it out that far.. Most of the big bore kits was done in the later model tractors,, SM, MTA, 400-450.. same as the SH, 300-350,, just has more meat in the block,, ChadS
IRISHRED
12-05-2003 18:50:15
 Re: Re: Re: Re: Boring M block in reply to ChadS, 12-05-2003 17:32:30
I bored a M block to 4 and 3/8 and have a little over .100 cylinder wall thickness without sleeves
