For ChadS
Jeremy
12-04-2003 18:34:55
Chad, What is the deal with the A,60,620,630 camshafts. Are they a different grind or not. I would like to know so I could try it. I had a Schooler cam, but it broke. I believe that the flywheel came loose, and the crank slid over enough to let the rods hit the cam and broke it in half. I also ground it totally round. The next one will be flat spot ground.
thanks Jeremy
greenweenie
12-06-2003 16:27:17
 Re: For ChadS in reply to Jeremy , 12-04-2003 18:34:55
If Schooler's cams are as crooked as he is, I'm surprised you could get it into the tractor. The late model grinds are basically the same as the early model grinds and if you have to buy a new cam, and your tractor is not built up a lot, I would probably stick a 630 cam in it.
