optimal compression ratio for a JD G?
Jonathan
12-02-2003 20:03:15
What is the best compression ratio for a G? To get the best HP out of it. I have read post from before on octane and wondered if there was much difference in the power of the tractor that runs 93 octane vs 110 octane given that the 110 oct. was higher compression tractor. thanks
a puller
12-03-2003 20:44:18
 Re: optimal compression ratio for a JD G? in reply to Jonathan, 12-02-2003 20:03:15
it is my opinion, but 9:1 is about perfect..we are haveing problems with anything more....
burns
12-03-2003 05:07:16
Being that this is my first post in a long time. I think I will refrain from stirring the pot with the compression topic.
To achieve a higher compression, the most common configuration deals with changing the head or pistons or head/piston combo. Most would agree that a flat head and high aluminum pistons yields a level of compression that can cause some problems (flat head flexing, head gasket troubles)that may require additional machine work. The cheapest way to achieve the 175-200 psi range is the cyclone head milled up to .250 (into the eyebrow) and aluminum pistons.
Compression is only one factor to consider when completing a total performance rebuid. (Air in-Air out, fuel, etc....)
Hope this helps
johndeereyellow
12-03-2003 17:13:49
 Re: Re: optimal compression ratio for a JD G? in reply to burns, 12-03-2003 05:07:16
Burns: Have not seen much of you this year. We would like to see more of the Burnsomatic up this way next year. Thumper likes the company. Near lookalikes.
a puller
12-03-2003 20:33:22
 Re: Re: Re: optimal compression ratio for a JD G? in reply to johndeereyellow, 12-03-2003 17:13:49
how did you do this year?? I made a post a while ago to see how your seasons lately have been....
Rich
12-03-2003 16:07:44
Burns welcome back, I thought you might go to Wauseon, but I didn't see the Burnsmatic.
burns
12-04-2003 03:42:50
 Re: Re: Re: optimal compression ratio for a JD G? in reply to Rich, 12-03-2003 16:07:44
I've been really busy with my regular job and working for the family business on the weekends and holidays.
Still a little ticked that I only made it to about 1/3 of the pulls this year when compared to last season. Busy replacing an active sanitary line the whole rainy month of July.
big jugs
12-05-2003 20:05:06
 Re: Re: Re: Re: optimal compression ratio for a JD in reply to burns, 12-04-2003 03:42:50
Have a bored and stroked g at 110 hp, at 11-1 comp. lugs fine in 2nd gear in 7000 class, in 5500 runs 3-4th gear, not too many will lug at all in those high of gears.
