Tractor rear-ends
Matt
12-02-2003 18:56:35
I have an IH 300 and there is an click in the rear-end when were are movng when the oil is warmed up. We took off the rear-end cover and did not find any gears that were missing teeth or any pieces in the bottom. There is a central planitary gear between the two bull gears and that moves side to side about a 1/4 inch.
I am on a limited budget and have thought of instead of tearing my rear-end apart, to just buy a different rear-end and bolt that on. Would an regular H or an Super H rear-end bolt on to my 300?? I would think this would be cheaper than trying to fix mine. Thanks.
Donnie
12-03-2003 22:59:55
 Re: Tractor rear-ends in reply to Matt, 12-02-2003 18:56:35
If your going to do a swap, get a rear end from a farmall 460. It will bolt up and you won't lose the torque. Done this with a 350 that the bull gear went threw the bottom of the rear end housing. Like Chad said sounds like something may be slightly off. Check and see if the sound is coming from an axle. Maybe like axle bearings. Seen several do that if a small piece of meatal gets in one. My 2 cents.
ChadS
12-02-2003 19:36:52
A H or super H will bolt on,, I belive,, Check the pattern on the bellhousing to the rear end, If not,,you could relace it from the bellhousing back,, you would lose the TA though,, It sounds like the brake pinion shafts need to be reshimmed,, Does it do it in all the gears?
