NATPA Rules on all flyweels covered.
LJS
11-30-2003 18:20:42
A couple weeks back I posted a question about the NATPA rules that stated
19. All flywheels must be covered.
I pull a hand start JD A
The NATPA contact I made could not tell me decisively that there was no problem with Div II hand start tractors, he did not think the rule was for that. He told me to call another gent that I will not name "don't remember the name" to get a definite answer. Any way I was wondering at Columbia, did they let any hand starts pull without a cover in div II and III
Thanks
Lynn Stallbaumer
greenweenie
12-03-2003 17:35:57
 Re: NATPA Rules on all flyweels covered. in reply to LJS, 11-30-2003 18:20:42
Lynn-
As stupid as some of the NATPA rules are, even they understand that you cannot stick your hand in between a flywheel and it's cover without causing yourself great bodily injury. One of the tech committee officals pulls a 36 JD A with electric start. The cover on this tractor was stainless steel, three inches wide, about fifty thousandths thick, fastened at the starter and the bottom of the case. There was a gap between the flywheel and cover you could throw a cat through. I can't help but believe that you couldn't get caught up in that mess just as quick if not faster than a flywheel with no cover at all. But to answer your question, they have decided that you do not have to have a cover over your flywheel.
LJS
12-03-2003 22:38:52
 Re: Re: NATPA Rules on all flyweels covered. in reply to greenweenie, 12-03-2003 17:35:57
Thanks for the info
Lynn
W. ANGLEMYER
12-01-2003 15:12:58
WAS AT NATPA PULL IN OHIO LAST WEEK END NO FLYWHEELS WERE COVERED IN DIV 2 OR 3 ALSO ALOT PULLED WITH OUT UP DATING ADJUSTER BRACKETS ON HITCH IN THE NATPA CLASSES
CASEPOWER
11-30-2003 19:30:46
Man down the road from me was useing his JD A the other day when he heard a knock. He shut it off and the flywheel had cracked bad. Never came loose and never had any previous damage. The older Cast gets the more of a chance it will crack or come apart. Cast is under preasure at all times and as it gets older it could come apart. For insurance and saftey reasons it may be the only answer. There is a article here on YT about a JD A flywheel comeing off and bounceing over a car in a on comeing lane.
LJS
11-30-2003 22:35:37
 Re: Re: NATPA Rules on all flyweels covered. in reply to CASEPOWER, 11-30-2003 19:30:46
I guess that would be a "no I was not there"!!!
ChadS
11-30-2003 19:26:40
I would think you could,, since the rpm is 10% over,, should be ok,, I think that rule is for tractors in div 4 and 5,, where the rpms are very high,, if not I got a few old A's,, have a starter bracket, flywheel and shield,, ChadS
