Performance camshaft for 1946 john deere B
Joe
11-30-2003 17:29:28
Where can I find a performance cam for a 1946 B? Anyone have one? did you notice a difference? Did it mess up your smooth ideling?
thanks alot!!!
ChadS
11-30-2003 18:48:31
 Re: Performance camshaft for 1946 john deere B in reply to Joe, 11-30-2003 17:29:28
Try using the same grind as a 50-530 jd. they have a better grind than the older Jd's,, worked in a A, Jd,, went to a 630 grind,, pulled alot better,, Just my 2 cents Chads
Joe
11-30-2003 19:19:05
 Re: Re: Performance camshaft for 1946 john deere B in reply to ChadS, 11-30-2003 18:48:31
So i should go to a junk yard and get a 530 cam?
ChadS
11-30-2003 19:24:06
 Re: Re: Re: Performance camshaft for 1946 john dee in reply to Joe, 11-30-2003 19:19:05
Yep,, I am not for sure if it will go into the B,, I took an A cam and the 630 cam to a shop and had the A cam matched to the 630.. ChadS
Jeremy Brault
12-01-2003 07:00:23
 Re: Re: Re: Re: Performance camshaft for 1946 john in reply to ChadS, 11-30-2003 19:24:06
Chad, Who ground the cam for you? Did it work better than a Schooler cam?
Jeremy
ChadS
12-01-2003 09:12:09
 Re: Re: Re: Re: Re: Performance camshaft for 1946 in reply to Jeremy Brault, 12-01-2003 07:00:23
Garete Engines in Rochester, Indiana,, I had them match the the 630 cam for the A.. It helped the lugging power alot,, and made the A sound like the 30 series tractor,, smoother idle.. I have never had a Schooler cam,, but they know what they are doing,, when you order performance cams,,, Here is what to tell them,, Cubic inches, rpm range, cfm of the carb, and the compression pressure. Most cam builders who have built cams for antiuqes, know what to do,, So I would say Schooler would be my first choice. ChadS
Jeremy Brault
12-01-2003 12:00:20
 Re: Re: Re: Re: Re: Re: Performance camshaft for 1 in reply to ChadS, 12-01-2003 09:12:09
Chad, I was told a 630 cam would fit in an A. nothing to change. What do you think, would that work. thanks, It would obviuosly be better.
Jeremy
ChadS
12-01-2003 13:12:32
 Re: Re: Re: Re: Re: Re: Re: Performance camshaft f in reply to Jeremy Brault, 12-01-2003 12:00:20
Worth a shot!! The A I was working with was a 41,, so it had the older block,, I did not think at the time that the cam would fit the older tractors,, but I would bet that the tractors from 48-52 the cam would go right in. You know,, the rpms was higher on the 630,, and was also redesigned for a 2 bbl carb,, (CAM) As the 2 cyl tractors got newer,, they got stronger, with less cubic inch,, better design, and enginerreing, ChadS
Drew
12-01-2003 14:36:18
 Re: Re: Re: Re: Re: Re: Re: Re: Performance camsha in reply to ChadS, 12-01-2003 13:12:32
Yes, the cam from a 48-52A will fit in an earlier one, as will a 60, 620, 630 cam. I don't know why you would want to use one of those cams instead of the one out of the 41A since they are the SAME grind.
ChadS
12-01-2003 15:34:43
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Performance ca in reply to Drew, 12-01-2003 14:36:18
Same as what? ChadS
Drew
12-01-2003 15:54:48
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Performanc in reply to ChadS, 12-01-2003 15:34:43
Styled A thru 630 cams are all the same grind. The 630 cam looks different because the lobes are narrower and there is a gear on the clutch side end for the distrubutor, but the actual cam grind is the same, whether its from a gasoline or LP tractor. The only thing putting a 630 cam in a styled A will do is blow a Saturday afternoon putting it in as you have not really changed anything.
CASEPOWER
11-30-2003 18:35:52
"smooth ideling?" I have yet to see a deere that idled smooth with a stock cam.
Joe
11-30-2003 19:18:10
 Re: Re: Performance camshaft for 1946 john deere B in reply to CASEPOWER, 11-30-2003 18:35:52
Mine idels as smooth as can be. go to JD tractor shows for proof.
