Piston Q for Chads and others
Nate
11-26-2003 16:02:20
Can the 806 piston be ran as is in an H with the proper stroke, or does it have to be modified. If so, how? Thanks to all.
ChadS
11-26-2003 17:23:04
 Re: Piston Q for Chads and others in reply to Nate, 11-26-2003 16:02:20
Yes, the 806 pistons can be used from 5 inch,, up to 5-3/4 stroke,, with stock rods. the wrist pin location is all that has to be changed.. (Bushing) ChadS
AC
11-26-2003 19:32:19
 Re: Re: Piston Q for Chads and others in reply to ChadS, 11-26-2003 17:23:04
But what piston has to be used with a 6 inch stroke?
ChadS
11-26-2003 23:29:12
 Re: Re: Re: Piston Q for Chads and others in reply to AC, 11-26-2003 19:32:19
Well, there is 2 piston types,, a 350 chevy 4 inch bore, or,, a 305 chevy for a smaller bore. will work for strokes above 5-3/4. Chads
AC
11-27-2003 05:59:27
 Re: Re: Re: Re: Piston Q for Chads and others in reply to ChadS, 11-26-2003 23:29:12
But do I want a dome, (if so, how high) or valve relief flattop, or what? I'll probably have to run hardblock, won't I? AC
