b heads
Johndeere junki
11-25-2003 15:58:28
im building a 41 john deere b with a 5" bore 6.50 stroke would you go with flat head or late head going to put big valves
2 Cylinder
11-26-2003 08:36:57
 Re: b heads in reply to Johndeere junkie, 11-25-2003 15:58:28
You might want to check the bolt patterns to see if they will interchange, as there may be several bolt patterns for the different year heads for the JD-B.
Johndeere junkie
11-26-2003 14:33:22
 Re: Re: b heads in reply to 2 Cylinder, 11-26-2003 08:36:57
they will work with alittle work i would like to know do i need flat head for compresstion or late head for air flow
