Super 88/880 puller and weight
Jake
11-24-2003 14:47:34
I have an Oliver 880 diesel but I have super 88 sheet metal on it so I can get into the older classes. Their are several 88's and even a super 88 diesel that pull in the 4500. The regular 88's gas or diesel seem to have no problem getting into the 4500. But my friends super 88 diesel can just get in with with 15.5X38's and all his weight brackets on. I however can only get down to 4700 with my weight brackets on. We both weigh right about 170. Our weight brackets are exactly the same down to the 1/16 of an inch. We are both running newer 15.5's. My question is what is on my tractor that makes mine 200 pounds heavier? Is the 880 frame or transmission heavier? Does anyone have any idea how to loose some more weight? Any help is appreciated!
770
11-25-2003 13:16:09
 Re: Super 88/880 puller and weight in reply to Jake, 11-24-2003 14:47:34
For starters, The frame is heavier, as well as the transmission, hubs... all the way down to the crankshaft. A few lbs here and there and before you know it....
upperpinecreek
11-25-2003 05:45:55
it is always amazing what people will do for a 25cent ribbon.
TimC
11-24-2003 20:22:50
I believe the 880 tub is a good bit beefier than the 88 tub.
Farmall Daddy
11-24-2003 16:35:06
If you have the torque amplifer unit on it, that would put you up that much. Hope this helps!
slowsmoke
11-24-2003 15:57:09
What front end do you have? try the 77 narrow. weld on hubs help too!
E J
11-24-2003 15:29:46
May have a 770 rear end.That is what I use.
Dave
11-24-2003 15:07:56
Hmmmmm m... 88 sheet metal on a newer tractor so that you can get into the antique classes.... Now if I can get the sheet metal from my B on the 4020.....
Don
11-24-2003 21:08:29
 Re: Re: Super 88/880 puller and weight in reply to Dave, 11-24-2003 15:07:56
Amen brother. Cheaters never prosper. Just like Ollies. Pull where you belong, then worry about the problem then.
Fleetline Steve
11-24-2003 20:01:23
Good post!
