Long stroke A john Deere's
JD nut
11-23-2003 15:02:15
I have a 1936 A John Deere and wondering how big pullers are building them? How big can it be build and hold together for more than a season?
Thanks for any information.
JDGnut
11-24-2003 08:32:34
 Re: Long stroke A john Deere's in reply to JD nut, 11-23-2003 15:02:15
9.25 is a good stroke on an A... too much more and you have to look at moving the Cam.. (A little more could probably be squized out... )
JDGnut
Jeremy Brault
11-24-2003 12:10:52
 Re: Re: Long stroke A john Deere's in reply to JDGnut, 11-24-2003 08:32:34
Hey,
I went 9in on a 42 A. it was very tight. you have to change the rod ends to 4020. then you have cut the back out of the crankcase. alos have to grind the cam
just my expierence
Jeremy
11-26-2003 11:43:14
 Re: Re: Re: Long stroke A john Deere's in reply to Jeremy Brault, 11-24-2003 12:10:52
if you go with a 2.75 journal instead of a 3"4020, you can get alot more clearence on the cam with a 9" crank....
