427 Continential in a MH 44-6
AirtimeWC
11-22-2003 18:27:02
Need info on this installation, I want to make a 44-6 for pulling. Stumbled upon a B427 Cont. and I want to put it into a 44. Are 44's and 44-6's the same, or is the 44-6 different as to frame length, size, clutch, etc. I believe the 427 is physically some bigger than the factory 226 Cont. Thanks in advance.
docjoe
11-23-2003 14:58:49
 Re: 427 Continential in a MH 44-6 in reply to AirtimeWC, 11-22-2003 18:27:02
airtime wc we had one on a fox silage chopper very sweet running engine. it will fit in your tractor ok but the sheet metal don't work out to well hard to hide. we had one in our neck of the woods years ago, it did run fair but a good m or u minnie would beat it. I think 85/90 hp was all they were. the one that was here was a 203 mh it came with a 331 engine i think?
AirtimeWC
11-23-2003 15:53:37
 Re: Re: 427 Continential in a MH 44-6 in reply to docjoe, 11-23-2003 14:58:49
The engine I have came off of a Fox chopper, it still has the sheet metal on it with the Fox decals. I measured the engine, it has a total length of about 38 inches from the front of crank pully to where the bell housing/clutch assembly bolts to the rear of the engine. How does this compare to the length of a 226? Also, do all Cont. engines have the same bolt pattern to attach the clutch? Need to know how to get it bolted up to the tractor clutch. Thanks.
DW
11-25-2003 14:52:36
 Re: Re: Re: 427 Continential in a MH 44-6 in reply to AirtimeWC, 11-23-2003 15:53:37
Block face/face MH 44-6___F226____25in
MH203____M330___30 3/4
Cont._____ B427____33 1/4
44-6 rear to pulley 28 1/2
Big shoehorn & blind eyes turned
CASEPOWER
11-22-2003 19:31:02
Theres one running around NC here with a Holley 4 barrel and NOS. He is illegal as they come, but don't get caught because he still don't win. Side covers hide alot. I have a 44-6 and a 44 out back I will check the length tommorow if no one tells you.
piston
11-23-2003 06:55:28
 Re: Re: 427 Continential in a MH 44-6 in reply to CASEPOWER, 11-22-2003 19:31:02
wonder what the 427 org. came in,truck bus, or train would love to have one would trade a stright 8 cyhsler, maybe
CASEPOWER
11-23-2003 14:34:20
 Re: Re: Re: 427 Continential in a MH 44-6 in reply to piston, 11-23-2003 06:55:28
They were power units and on irration pumps. They look just like the 226 on a bigger scale.
slowsmoke
11-23-2003 05:19:15
44'S and 44-6's are the same frame/trans./etc, just on had the 6 cyl., other had the 4 cyl. cont. Good luck
ChadS
11-23-2003 18:18:15
 Re: Re: Re: 427 Continential in a MH 44-6 in reply to slowsmoke, 11-23-2003 05:19:15
Would your rules let you run a Chrysler flathead in it? It would bolt in,, no mods Chads
piston
11-23-2003 19:34:57
 Re: Re: Re: Re: 427 Continential in a MH 44-6 in reply to ChadS, 11-23-2003 18:18:15
got lose in math, 300 verses 427, true a easy swap on chysler, but????
