Ideas for a 264 farmall M
Farmall FREAK
11-20-2003 14:46:22
We pull this M in 4500 to 6600 and where wondering what could be done to the engine to gain about 5 -10 more horsepower....we have a 264 gas engine with big valves and ported and polished, dry element air filter, MSD box, electronic ignition, and governor running max legal RPM....What could we do?? ideas on how to tune up the carb and how much HP if any would you gain from an LP manifold or Denny's manifold :(..... THANX YALL
bud barenie
11-22-2003 17:48:09
 Re: Ideas for a 264 farmall M in reply to Farmall FREAK, 11-20-2003 14:46:22
there is an add in hook mag, a new company making anew version of the old m@w components !! you need to check the head casting number to see what style of head is on the tractor first !!! mill the head a bunch !!! over 40ths ! definnitely find a propane manifold and spend some time maching it ti the head. if your close to indiana have chads tune the tractor on their dyn. check your bore diameter !!! what type of cam is in the tractor !!! come up wih your own compression ratio (cc the head) you be amazed how low compression the stock (m's) are !! my 22cents worth
FB
11-22-2003 17:53:21
 Re: Re: Ideas for a 264 farmall M in reply to bud barenie, 11-22-2003 17:48:09
i saw thos ein there...they even say they can offset the wrist pin for bigger strokes, wonder what pricesm they are chargin? anyone know?
mill the head .15
11-21-2003 11:08:36
should be good for 5 or so
ChadS
11-21-2003 10:14:33
Not trying to sell anything,, but I have come up with a kit that will give you what you are looking for. No boring, stroking. It is all done in the head gasket, carb, distributor, and governor spring. My email address is [email protected] if you are interested in discussing this further. ChadS
Wild Horses
11-21-2003 10:05:44
If all you;re looking for is 5-10 horse. Swap out the manifold for a 400 manifold with the three fins instead of the block between the intake & exhaust runners. I don't know exactly what it will gain you but that should get you the results you're looking for.
supermpuller4
11-20-2003 15:11:41
A 281 cu. motor would help or better yet a 4.25 bore makes a mean 298cu. engine. Don't buy anything from Denny, get a lp manifold or call Hank Steel in Mich. he can set you up with a good manifold.
