How much stroke for John Deere G ?
JD720
11-19-2003 16:14:52
Just how much can you stroke a G before you get into too many problems.I dont mind cutting the back out of the crankcase and grinding notches in the cam but I just dont want to have to move the cam or anything like that.What is the best way to cut the back out of the crankcase ? Thank you
Jeremy Brault
11-20-2003 06:34:35
 Re: How much stroke for John Deere G ? in reply to JD720, 11-19-2003 16:14:52
I went 9" in my 42 A JD. it was very tight. we had to grind the cam to make it fit. then the cam broke, so i have to start over again. I had it ground perfectly round, bad idea. The best way to cut the back of the crankcase out is to use a cut off wheel on a 4/1/2" die grinder. that worked good for us on the A. Jeremy
1950JDG
11-20-2003 06:25:24
Hey 720;
My Dad and I have a 9.250" crank in our '47 G, and it is only bored .125" over witha few other gadgets, and it pulls great. To cut the back of the case, RENT A PLASMA CUTTER for a few days, as I have cut a few cases with the die grinder, and unless you have a sadistic side and want to empty the transmission to clean all of the gears and bearings, the plasma cutter is the only way to go, as it cuts so clean. Tyler hit it right on the head, you are not really gaining anything going much bigger. As for the rods, go with the back half of a 4020 gas rod, and the front half of an "A" rod, but try to keep the compression below 10:1 or as it has been stated many times before, the lugging power of the Deere goes away. Just my .02 cents
R/
Eric
Tyler Neff
11-19-2003 19:16:38
I ran a 9.75 in a G for a year or two. I also ran a 9.25.Both of these require you to romove some of the back wall in the crankcase. I can honestly say that the horsepower between the two were about the same.They both had 6.75 bore and Jerrys heads and manifolds.I truly believe it was a waste of time putting the extra half inch of stroke in compared to the amount of HP I gained . The amount of grinding is alot different between those two strokes. I didnt think it would make that much of a difference but it does. Im running a 9.5 in my 70 gas right now and it fit just right. I guess Im trying to say 9.25 or 9.5 would be plenty. Have FUN. TYLER
JD720
11-20-2003 21:57:59
 Re: Re: How much stroke for John Deere G ? in reply to Tyler Neff, 11-19-2003 19:16:38
Thank you all.I think I will take your advice and go with a 9 3/8 and be done with it.It sounds like that is about the best way to go.
Flogger
11-20-2003 04:47:49
Do you have to do anything special to the block to run a 6.75 bore?
like Tyler said...
11-19-2003 20:15:26
I would stick in the mid to low 9's. 9.375 seems to be a popular stroke in the G's right now, so I'd aim for that area. It's reliable too.
crkw2 pulling team
07-19-2005 21:31:22
 Re: Re: Re: How much stroke for John Deere G ? in reply to like Tyler said..., 11-19-2003 20:15:26
idd like to say that i know where there is one thats 10" one and 2 that are 9.75 and they are still goin fine.
buickanddeere
11-19-2003 20:04:28
Which rods are/were the tractors using?
