Which is the most popular(5000-7500)classes?
Roger
09-28-2001 08:11:13
I have seen tons of Farmalls in these classes.I was wondering how it is at pulls in other places.I don't see many Olivers in these classes either.I am in the midsouth area.I am speaking of (supposidly)farm stock tractors.Thanks Roger.
joecool
10-01-2001 16:02:51
 Re: Which is the most popular(5000-7500)classes? in reply to Roger, 09-28-2001 08:11:13
I pull a stock case DC in the 5500 class. My wife just won first place in Houston, MS this past weekend. The tractor is stock, water in rear tires, tire pressure set at 17, 18 inch hitch height. we compete 90% of the time against other stock tractors, 1960 and older. Yes she did beat several super M', big JD's and others.
Red Rider
09-30-2001 21:04:23
I pull in those classes with Bone Stock Farmall tractors. I pull a 300 with a 169cu engine and a 400 Diesel with a 264cu engine. Its getting harder and harder to compete in the so called stock tractor class. Most are not stock. In the 6 to 7 thousand pount class I pull against Farmall 560 tractors. These tractors came stock with 65HP the 300 came with 35HP. Somehow this just doesn't seem right. I don't get any first place trophys but I get quit a few 2nd and 3rds
jimmy funk
10-01-2001 16:11:07
 Re: Re: Which is the most popular(5000-7500)classes? in reply to Red Rider, 09-30-2001 21:04:23
i pull a farmall h,m,and recentley bought a 560i think that a oliver 88 or77 is good fore the 4000 4500and 5000 after that when the old red ones hok up there is no stoping them wether it is in 14,500 with a 1066 ore 8500 with a 560 and i now how u feaal i bought my m at a sale it wasent running but it had a brush hog on it and the farm was mowed no body was bidding i paid 1200.00 dollas fore it we got it home and put the basicks in it plugs disibuter and battery it runs like a top we recentley found out it was just rebult i live in carrollton and i pulled at kilgore there is a tractore called indale miricle and it has a 806 in a 460 it rained just before my class and i went in first gear and all the suped up tractors were runing wide open and i went nice and slow i won the class out of 52 and mindale miricle waent to happy it just goes to show cheaters dont alwas win
charles
09-30-2001 18:19:49
I pull a oliver 88 modified running a 1800 engine I like pulling #4500 in 4th gr running 6000 rpm. run #5500-#6500 in 3ed at 6000 rpm. talk about a has run. come out of the hole at 4500 rpm. also pull a wd6 IH stock in #5500-7500 1st gr at 1800 rpm. it diesel its 300 cid
Red Rider
09-30-2001 21:08:30
 Re: Re: Which is the most popular(5000-7500)classes? in reply to charles, 09-30-2001 18:19:49
Hey, how do you get 300 cubes out of your WD6? You would have to have 4 1/4 pistons to get 298. I have not been able to find any sleeve and pistons sets for these diesel that large.
Al
09-29-2001 04:01:11
Roger in Michigan it's Farmall and John Deere. They are easy to find tractors and reasonably cheap. It's easier to figure out how to set your tractor for a particular track when there arehalf a dozen others just like your's going down the track first. ;-)
I pull an stock Oliver 88 standard from 5500 to 7500 with no problems. Next year I hope to pull from 4500 to 7500. There aren't very many hooks over 7500 around for a stock tractor. I will get more hooks going lighter than heavier.
Al
Jim
09-28-2001 17:29:03
Rodger: My dad and I pull in Central Florida. We bought a Case DC in March so we could compete in the 5500# and 6500# classes which seem to have the most tractors to compete against. Lots of Farmall's down here also. Lots of J/D's also
