Wasseon Ohio pull rules, and time??
Farmall Daddy
11-16-2003 05:56:24
Would like to know what time the pull starts, and possible what rules I can exspect. Hitch heights, 100 pounds extra for wheelie bars, weight classes, $ for each hook, how many times you can hook per class, money, or trophie classes, and division classes. Thanks in advance!!
Kevin Banet
11-16-2003 14:53:42
 Re: Wasseon Ohio pull rules, and time?? in reply to Farmall Daddy, 11-16-2003 05:56:24
Hi Guys!!!!They pull div 2 on fri. and on sat. On fri they use coatpa rules the maumee valley pullers run the show on fri. on sat. the natpa along with maumee valley pullers do the show . you need a kill switch on the tractors they run every 500 lb classes up to the 9500 yes you have to have wheeley bars. No they do not give any allowances for weight. You can go to the clubs web site for more info. including rules and contact numbers. Their web site is www.maumeevalleypullers.com, we will be going up there with one set of scales and our scoreboard, and at least one tractor.
And yes the entry fee is $25.00 with payback. The rules for Fri. are a little looser than Sat. rules.
But you guys would be competitive with the wd, or the M.
Farmall Daddy
11-16-2003 15:51:56
 Re: Re: Wasseon Ohio pull rules, and time?? in reply to Kevin Banet, 11-16-2003 14:53:42
Just got the motor back in the WC, but we are having power trouble with the M. We think that the distributer has worn out. Plan on restoring the Oliver. Bought Doc's tires off his 620 JD, and plan on getting them on the Oliver here pretty soon. May have to overhaul the 560 this winter. Compression rings are worn out. Have a lot to do, but next year, we plan on coming out with a lot more horsepower in all of them.
kevin b.
11-16-2003 16:14:26
 Re: Re: Re: Wasseon Ohio pull rules, and time?? in reply to Farmall Daddy, 11-16-2003 15:51:56
Are you going to wauseon? LOT OF OUR GUYS WENT LOST YEAR WAS GREAT TIME!!!
Farmall Daddy
11-17-2003 15:52:01
 Re: Re: Re: Re: Wasseon Ohio pull rules, and time? in reply to kevin b., 11-16-2003 16:14:26
Would like to make it up there, but have to get the Oliver's tires changed, and the WC back in pulling condition. Might make it, and we might not. Good luck if we don't get up there!!
slowsmoke
11-16-2003 06:32:51
Try This Link acording to this add, there is no Div 2, 5500/6000/6500 with natpa rules. I do know that there is NO added weight, 4500LB.s means 4500 Lb.s Div 2 is 18" hitch, Dav 3/4/5/ is 20" . $25 hook, Hope this is some help, Don
Farmall Daddy
11-16-2003 07:15:01
 Re: Re: Wasseon Ohio pull rules, and time?? in reply to slowsmoke, 11-16-2003 06:32:51
Thanks for the help. Printed off the forum, and hope to make it there.
