HP VS COMPRESSION
Jonathan
11-14-2003 09:26:22
What kind of hp difference would you get by bumping up from 6.5 to 8.5 compression on a JD G? or is it a waste of time. thanks for any info
Paul
11-14-2003 20:40:35
 Re: HP VS COMPRESSION in reply to Jonathan, 11-14-2003 09:26:22
I have always been told that you will gain about 10% for each point of compression raised .on a 50 horse tracor you might gain 10 horse in theory. Paul
Jack
11-14-2003 09:44:47
My 53 G had 50 hp at 540 pto rpm's at 110 psi per cylinder.I installed new valves and shaved the head .250 thousanths and went from 110 psi to 136 psi and went from 50 hp to 56 at 540 and 59 at 450 pto rpm's.Hope this helps.
