Oliver Hitch NATPA Legal??? Take a look.
Jim F.
11-14-2003 05:26:35
Well, will this pass NATPA inspection?
Link
where's the picture??
11-14-2003 07:11:44
 Re: Oliver Hitch NATPA Legal??? Take a look. in reply to Jim F., 11-14-2003 05:26:35
I'm looking but don't see nothing
Jim F.
11-14-2003 07:20:40
 Re: Re: Oliver Hitch NATPA Legal??? Take a look. in reply to where's the picture??, 11-14-2003 07:11:44
Sorry guys... If you would copy the address and paste it in your browser, it should work that way.
I was unsure how to post a picture within the forum pages...
a puller
11-14-2003 07:56:11
 Re: Re: Re: Oliver Hitch NATPA Legal??? Take a loo in reply to Jim F., 11-14-2003 07:20:40
it still comes up error on my computer....
Jim F.
11-14-2003 08:29:32
 Re: Re: Re: Re: Oliver Hitch NATPA Legal??? Take a in reply to a puller, 11-14-2003 07:56:11
I�m sorry for the confusion� will you please try this link?
The picture is in the �tractor� album and the photo is titled Ollie 88 hitch.
Link
NOT
11-14-2003 08:42:21
 Re: Re: Re: Re: Re: Oliver Hitch NATPA Legal??? Ta in reply to Jim F., 11-14-2003 08:29:32
Just from what I read from the rules that were posted I would say no. The adjusters are mounted about the center of the axle.
Jim F.
11-14-2003 08:44:40
 Re: Re: Re: Re: Re: Re: Oliver Hitch NATPA Legal?? in reply to NOT, 11-14-2003 08:42:21
Actually the top of the adjusters are below the centerline of the rear axle.
Donnie
11-14-2003 09:24:08
 Re: Re: Re: Re: Re: Re: Re: Oliver Hitch NATPA Leg in reply to Jim F., 11-14-2003 08:44:40
I think you might still have problems. They are still connected above the axles. Even if the adjusters are below. Dollar to a doughnut says the won't like it. Nice looking Ollie though. I like the all yellow wheels. Good luck.
Alan
11-14-2003 18:42:52
 Re: Re: Re: Re: Re: Re: Re: Re: Oliver Hitch NATPA in reply to Donnie , 11-14-2003 09:24:08
I'm facing the same delema w/ my 88. Would a simple brace ran from the top of the adjuster itself to the bolts that hold the axel housing to the transmission case satisfy the rules???
Thanks,
Alan
Jeff
11-14-2003 21:37:24
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Oliver Hitch N in reply to Alan, 11-14-2003 18:42:52
I looked at that myself on my 88 and I think it should pass. However if the rule states that the adjuster has to be connected below the center point then technically (and NATPA uses that alot!) you can run a short piece of steel down from the original connecting points to just a little below the center of the axle and attach them there.
Would probably depend on who is teching your tractor that day and how good you pulled if they would allow or disqualify you. Just make sure you don't win the first time or two and they probably won't bother you.
On the upside of it all though it looks to me like if you attach the adjusters below the center line it will change the way your tractor pulls also since the angle is changed. Seems as though it wouldn't pull down on the tractor as much because of this thus making it not pull as far. Realise I am just guessing on that and stating that opinion
Puller
11-14-2003 19:15:20
Leave your hitches alone and go to U.S.A.P pulls, the adjusters are not the problem, It's the flimsey metal that the adjusters are connected to!! N.A.T.P.A I thought your rules had wheelie bars, Or is this just another one of Bear and Birch rules.
slowsmoke
11-15-2003 04:58:14
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Oliver Hit in reply to Puller, 11-14-2003 19:15:20
there are no usap pulls near me, so that won't do. Try answering the question,, instead of bashing
