HEY DICK L.
kevin banet
11-13-2003 16:43:53
Hey Lamar if a kill switch is your only problem. Then my brother John can fix you up, for between $3.00-$4.00. Better get permission from the boss (ha ha), just kidding to go to Wauseon. We are going to have our scoreboard and one set of scales there. We can put it on in about 10 min. friday morning. We can put it right on the tractor without drilling any holes. Last year alot of our pullers from around the area did real good I bet you might too. Could do any worse than me last year in 6000 I got last, but John was in the middle to the top of the class last year. Think about!!! Later!!!
Kevin
Dick L
11-13-2003 17:21:16
 Re: HEY DICK L. in reply to kevin banet, 11-13-2003 16:43:53
Installing and hooking it up is and was not a problem. I thought you had to have a special device that was designed for that purpose only. Slo let me know that all it would need to be would be a short plug in an outlet receptical with a ring attached.
Ya I know you saw how I have to beg Dixie to get to go to a pull.
Nuther problem will be getting weights around and mounted to make 3500# for Friday. The Oliver 77 is ready to go at 4500# but short on power for that pull.
Only other thing that would keep me home would be the cold. Man at my age I don't like the cold.
k.banet
11-13-2003 17:37:22
 Re: Re: HEY DICK L. in reply to Dick L, 11-13-2003 17:21:16
i seen 77 it will do ok in 4500.you know they run every 500 from 3500,4000,4500,5000,and so on.good luck with wife!!
