a JD BORING question
MPS
11-13-2003 05:32:17
How much can you bore a JD B block (1947). I've found a set of .90 over pistons and rings. Can I get any bigger pistons? thanks in advance
B-Borer
11-23-2003 08:04:05
 Re: a JD BORING question in reply to MPS, 11-13-2003 05:32:17
I have bored an early B .250 and used later model pistons. I guess it depends on what year u r boring and if u can find pistons.
bigger
11-13-2003 15:40:36
John Deere made up to .125 over pistons for those tractors. The difference in horsepower between the .045, .090, and .125 pistons is minimal. If you can find the pistons the block can safely be bored .250 over, maybe even .300 depending on how much compression you have. Those pistons weren't made by Deere though and are from other engines.
