Diesel Injection Theory ?
ToddF
11-12-2003 06:26:18
In relation to the power stroke of a four cycle engine, how does the deisel injection timing and duration compare? During the injection duration is it optimal to have constant fuel flow or variable flow? I suppose with mechanical injection it is impossible to avoid the ramp up and down of the injection rate of fuel. I would appreciate any insight I can get on this topic....ToddF
G-MAN
11-12-2003 07:40:43
 Re: Diesel Injection Theory ? in reply to ToddF, 11-12-2003 06:26:18
I would say that is going to depend on the type of engine, application, speed and dozens of other factors. One of the benefits of electronic unit injection is the ability to control duration of injection, injection pressure, timing and so forth, for maximum power, efficiency and reduced emissions. You can even have "pilot injection", which basically divides the injection process into two parts, to aid in cold weather starting. I don't know if anyone has played with electronic fuel injection in the pulling world. It would be interesting to see.
FULLPULLER#1
11-12-2003 11:10:17
 Re: Re: Diesel Injection Theory ? in reply to G-MAN, 11-12-2003 07:40:43
Yes there is people out ther playing with Elc.diesel inj.,,the trouble is that clubs like natpa won't let or will rule out this type.SO,people are going else where as so may others will in the near future.
