Flat Plat For a 50 JD G
LRN
11-11-2003 11:50:26
I want to lighten my 50 JD G up a little. Does someone know how much I can gain by removing the Hy system and replacing it with the flat back. Also if anyone has one I'd be interested.
Thanks, LRN
520-LP
11-11-2003 18:55:26
 Re: Flat Plat For a 50 JD G in reply to LRN, 11-11-2003 11:50:26
K&K has an alum one that the battery box will fit on for around $200.00 317-398-9883 you will loose 200 to 250 lbs
a puller
11-12-2003 03:43:55
 Re: Re: Flat Plat For a 50 JD G in reply to 520-LP, 11-11-2003 18:55:26
does it have the pto in it??? thanks, a puller
G-MAN
11-12-2003 18:00:23
 Re: Re: Re: Flat Plat For a 50 JD G in reply to a puller, 11-12-2003 03:43:55
There was a gentleman a while back who contacted me when I was considering getting an original flat-back for my '48 "G", which would be for a battery-box seat, but I can't remeber his name or location. You have to be careful with an aluminum cover, because a lot of places won't let you run one. I ultimately decided that although his asking price certainly seemed reasonable for such a rare item, it was a little out of my price range. I went ahead and gutted my stock power-trol housing - remove the rockshaft, cylinder, valve assembly, pump gears and so forth. I did leave the PTO shaft in place, though. I never weighed the parts I removed, but I imagine it easily took off 100+ pounds.
520-L
11-12-2003 17:17:45
No,but has the long shank where the pto goes .but would have to be machined out they also have one for an A
