NATPA Rule on flywheels
LJS
11-06-2003 21:59:04
third party image
On the natpa.com website is read they have added a rule on flywheels.
19. All flywheels must be covered. All exhaust pipes must be straight up with no curves or bends. (This change was mandated by safety committee on 7/30/03.)
This is on the general rules page.
I pull divII with a 1938 A that is hand start. Is this correct that I am going to have to put a cover on the flywheel. That is going to make a bi*&(^ to start. Is this correct for Div II or is this for the Div 4-5 tractors.
See the link below and look under general rules.
LJS
minnie ub
11-08-2003 16:01:34
 Re: NATPA Rule on flywheels in reply to LJS, 11-06-2003 21:59:04
according to burch in the hook its only on div 5 tractors. whats the purpose of the curved pipe rule.
HMMMMMmmm
11-07-2003 12:39:14
The reason they did this is because of that AC's flywheel blowing apart right? Well even they know a scatter blanket wasn't the problem, it was their not keeping the RPM's down so now their trying to get some heat off of them in muy opnion...They admitted the AC was apparently running unlimited RPM
Ohio M Puller
11-07-2003 12:24:21
LJS, to you the best thing to do is call someone with your question, cause as you see your not getting the answer you are truely looking for. I could only immagian that like all rules their are exceptions and in your situation like others could be handled before you travel to far to not be able to pull. I would say call someone in the tech committee or safety crew, a phone call is alot cheaper than gas in the truck to a pull.
Ohio M Puller
FULLPULLER#1
11-07-2003 11:51:29
The general rule says ALL flywheels must be covered,,,,,Now in Div.5 it states the flywheel must be covered with 3/8 thick steel,or,scatter blanket,,,,, ,
Do you have eny idea how HEAVY a 3/8 thick steel cover will be!,and where are you going to bolt it to?,are you going to use 1/2 inch bolts to hold it on what ever you bolt it to?,the bolts will be the week link on this set up,AND the blankets cost $$$$$$$$ lots of $$$$$$$$,,,,ALSO in the general rules, if the flywheel must be covered for all tractors than what will be the standard that the TecK "clowns" will approve,sheet metal?,bath towel?,paper towel?,paint?,cardboard?,WHAT?!,,,,, ,This just shows that if you can't beet them on the track,,beet them in the pits!,,,Are we seeing another year of BEAR mentality for the natpa?
Brian
11-07-2003 10:35:47
I am not sure what they are thinking but I sure hope someone can shed some light on this rule. The only way I could see it working on a JD is if you make a shield that will attach to the tractor after it has been started. I believe this would be a very big safety hazard. Please respond if you have any information on this issue. Thanks Brian
XNATPA
11-07-2003 07:36:50
Well I guess this is just one more reason not to pull with the NATPA. To put a cover on a hand crank flywheel tractor after you have started it or to have some kind of guard or shield in the way to get wound up in would be a bigger hazard than leaving it off. But you know they know best! I suppose they think that pull or bump starting these tractors well be a safer way to go? I don't think so! I sure am glad they thought this one out before they made this rule. Well I guess we will have to wait and see what the cronies will do about this one
Jim F.
11-07-2003 07:52:41
 Re: Re: NATPA Rule on flywheels in reply to XNATPA, 11-07-2003 07:36:50
Instead of bashing the NATPA, look at the big picture. I am sure they put this rule in place along with other rules as a cover your a$$ type of deal. Look around at some accidents that have occurred the insurance for our sport along with everything else is going to become more expensive in the near future and if clubs can put in place a few rules and enforce them to please the insurance companies to keep the premiums down.
It is hard to keep the rules simple and brief, the biggest thing is safety and to have fun.
My $.02.
XNATPA
11-07-2003 10:56:08
 Re: Re: Re: NATPA Rule on flywheels in reply to Jim F., 11-07-2003 07:52:41
Nothing wrong with safety, my point was these guys are creating a bigger hazard and liability. That's why they don't say what to do just that you have to do it. This rule is a big joke plain and simple. If they had a safe way to start theses engines with shields and a way to verify there purpose like they do with the wheelie bars I wouldn't say this. By the way my tractors do have wheelie bars behind the rear wheels far enough to do some good and anyone is welcome to jack them up too, along with that they have emergency stop cables and switches. I have nothing against safety, but lets use our heads for something other than to carry our cap around! This is a ridiculous rule for a hand crank flywheel two cylinder tractor. If RPM's were kept and enforced as they originally were then this would not be an issue now would it. But guess who couldn't leave that alone?? If these division five tractors think they need all this RPM they should grow some hair on there a$$ and go pro. Leave the RPM down like antique pulling was originally intended. Boils back down to the real root of there problem. To many cronies on the board with deep pockets having the rules to there favor. Afraid it will never change either.
scottie
11-07-2003 11:24:40
 Re: Re: Re: Re: NATPA Rule on flywheels in reply to XNATPA, 11-07-2003 10:56:08
The only ones wanting rpms I hear is Bear and posse. However, a JD flywheel is a big chunck to cover.
TimC
11-07-2003 14:05:02
 Re: Re: Re: Re: Re: NATPA Rule on flywheels in reply to scottie, 11-07-2003 11:24:40
Still not using your real name???
Bob
11-07-2003 09:31:29
Even if the flywheel is covered, I can't imagine a piece of sheet metal is going to slow down the chunks of an exploding flywheel on an old Deere.
A loose interpretation would allow me to cover the flywheel with paint, wouldn't it? The rule just says it has to be covered, but doesn't specify what it needs to be covered with.
well...,
11-07-2003 14:52:06
 Re: Re: Re: Re: NATPA Rule on flywheels in reply to Bob, 11-07-2003 09:31:29
realistically a stock flywheel isn't gonna give you any trouble at 20 or 30% over RPM. But if you start turning big time over stock R's, it takes a lot more than a dinky shield to stop it. Like that diesel that had the flywheel blow apart on it in Lebanon, KY this summer, it cut the tractor in half and shredded the scatter blanket.
