Leaky head
Mike
09-22-2001 18:12:37
I have an IH D-282 with the sleeves removed.We have made a cast iron ring insert to assume the portion of the sleeve, with .045 wire on both sides of the ring insert.(block & deck side) The ring is flush with the top of the deck, the wire is .015-.020 above the deck with a.063 copper gasket and it still leaks what do i need to do to fix it? This is a turbo charged engine runnig around 30lbs.of boost. Any help would be greatly appreciated Thank you
Dave N
09-23-2001 05:26:01
 Re: Leaky head in reply to Mike, 09-22-2001 18:12:37
Where do you seem to have the leakage from top of ring bottom of ring? are you blowing head gaskets?How much leakage are we talking about?
