Atempting Case DC puller
Dave S
11-06-2003 08:37:45
Hi, I just bought a case DC-4 for my sons FFA project. He wants to modify it some and give it a face lift later. He would like to try pulling this tractor at local pulls. The tractor has a mag, has good comp., and runs good. I told him I belive to get the most bang for the buck I would have the head milled as far as it could go safely, have pushrods shortend to match material removed from head, open plug gap,set valves a little tighter, and play with carb adjustment. He is on a tight budget. Any other ideas? Thanks
Jrred
11-11-2003 19:14:37
 Re: Atempting Case DC puller in reply to Dave S, 11-06-2003 08:37:45
Dave if you are going to deck the head then your best bet would be to port and polish it also, air flow is the name of the game
Wild Horses
11-06-2003 10:14:42
I have a few buddies here that pulls DC's. They're realy strong in stock trim. With a few cheap tricks and a diet, you'll do just fine. Another thing one friend does is leaving the hitch long, it always gets traction even when the "big boys" w/ cut tires.
dctom
11-06-2003 09:11:45
Dave; he is getting close if you want e mail me at [email protected] I pull a DC and do quite welll with it here i willl help yu and your son all i can DCTOM
