reduction gears
Jim Jones
11-05-2003 14:48:27
I have a 47 A ----Its apart for camshaft work----was looking at the reduction gears===they were saying change me ....Is it possible to change the ratio?-- at this time, first gear is quite fast and i am running out of motor in 6500---any easy swaps to be made???? Thank Jim.
vjohnyboy
11-05-2003 19:37:15
 Re: reduction gears in reply to Jim Jones, 11-05-2003 14:48:27
there is alot you can do but i recomend this 250 over bore camshaft for a torque cam change timing advancement and airflow it and also a set of piston of mine this will stop cutting away at needed casting. by wacking head and block you weaken them and this a two piece tractor someday but by adding a set of high compression pistons stops that need
puller
11-05-2003 19:11:19
Jim,Budd, where are you pulling, what type of tracks are you pulling on?What size tires are you guys pulling?
Jim
11-06-2003 15:50:26
 Re: Re: reduction gears in reply to puller, 11-05-2003 19:11:19
Pulling in central NY ---tracks are mostly clay with a stone dust mix----Tire size are 13.5 x 38==old tires===kelley sprinfield can't slip tires with 45deg. lugs===
520-LP
11-05-2003 19:00:01
Jim you need a set of gears out of a late A [one with the six straight gears} change reduction gear and complete pulley if possible as it will have a much better clutch {it will have a extra clutch disk} will slow the tractor down about 1/4 mile per hr.and give you more torque.
Jim
11-06-2003 15:57:12
 Re: Re: reduction gears in reply to 520-LP, 11-05-2003 19:00:01
The clutch that is on it now has a double disc clutch.are they different on the 50s styled A's ?
BUDD
11-05-2003 15:30:28
Jim;
I just read your post again. Now I have a Q. for you, How do you get to the 6500 before you run out of power? I have a 49 "A" that pulls decent and I run out at 5500. I heled you now HELP me!
('':'') BUDD
Jim
11-05-2003 17:49:39
 Re: Re: reduction gears in reply to BUDD, 11-05-2003 15:30:28
Budd----- Well long story made short----- port and polished the head,---shaved the block 40k.and the head 10k----3 way cut on the valve seats--new valve guides---bored the block .125 over size==opened up the intake ===bypassed the o.e.m.air filter--went with a papper filter==(K&N)...fuel does make a difference---when i dynoed it I had 87 octane fuel--while still on the dyno I drained it and put 94 octane in----instant 2 hp...max hores came with 36-40 deg.timing with a distributor---not the mag---also hotter coil...I had 42hp.at the pto last year===hoping to get into the 50s this year----this year i am changing the camshaft configuration, and taking another 150k off the block,installing elctronic ignition... By the way---the clutch side reduction gear looks to be pressed on----the other gear fits a splined shaft---or if need be taken off by removing the rivits and heating the ring gear like you would a starter gear...What did you use for replacment gears,,,what kind of difference was there?. Thanks Jim.
BUDD
11-08-2003 01:29:59
 Re: Re: Re: reduction gears in reply to Jim, 11-05-2003 17:49:39
Jim;
I sent you an E-Mail.
BUDD
11-05-2003 15:24:08
Jim;
I would say yes this is an easy swap. I did this same thing this summer. It took my son and I a total of 5 hours from start to finish. I am assuming that you first reduction gear is the spline type as mine was. There is a small area of Seral numbers that will not work as they are a keyed type of gear. I do not have my book handy but if you look at these gears in the parts book you can figure it out. We changed the first reduction and the gear that is pressed onto the clutch only. I was told that I needed to replace the whole clucth, but that is not needed. Let me know if you need more info. ('';'') BUDD
