Front End
Matt
11-03-2003 18:30:53
Is there a front end that weighs less than a stock one for an IH 300?? Want one that will bolt right on. One of a 460?? Would one off of a C or a tractor of that size fit? I have also heard that one off of some massy would work. Thanks.
nastym
11-04-2003 09:53:38
 Re: Front End in reply to Matt, 11-03-2003 18:30:53
Don't buy one. Go with what supermpuller4 say and make one. It's easy and only take a couple of hours. Good luck!!
tim
11-05-2003 19:46:23
 Re: Re: Front End in reply to nastym, 11-04-2003 09:53:38
whats wrong with buying one? wouldnt it be cheaper?? just go to a slavage yard or to a junk yard and get one
Ohio M Puller
11-04-2003 07:09:24
Matt,
We make light weight frontends if you are interested. Email me for info.
supermpuller4
11-03-2003 18:47:49
Make your own, all you need is plate, pipe, and rear axle stub off any front wheel drive car.
WILDMAN
11-05-2003 12:35:24
 Re: Re: Front End in reply to supermpuller4, 11-03-2003 18:47:49
WE MADE OURS WITH PLATE PIPE AND WELD ON AXELS FROM TRAILOR SUPPLY HAS A CHEVY PATTERN.
ChadS
11-05-2003 13:50:35
 Re: Re: Re: Front End in reply to WILDMAN, 11-05-2003 12:35:24
I am getting ready to build one or get ahold of OMP, to get one. I need to lose about 150 lbs to get ready for princeton, ChadS
AC
11-06-2003 07:52:58
 Re: Re: Re: Re: Front End in reply to ChadS, 11-05-2003 13:50:35
You still looking for W4 axle housings? AC
ChadS
11-06-2003 14:21:42
 Re: Re: Re: Re: Re: Front End in reply to AC, 11-06-2003 07:52:58
Yes,, Send me an email. [email protected] thanks Chads
