F-20 flywheel question
Chads
11-03-2003 09:24:04
How does the f-20 flywheel come off the crankshaft?? ChadS
Mike S
11-04-2003 09:05:58
 Re: F-20 flywheel question in reply to Chads, 11-03-2003 09:24:04
you willhave to first pull the tapered pin then make a puller to pull the flywheel, make the puller strong it comes off HARD!!!!!. I have pulled 4 of them. If you need a picture of the puller I made I could send you one.
ChadS
11-04-2003 17:02:50
 Re: Re: F-20 flywheel question in reply to Mike S, 11-04-2003 09:05:58
Thank you.. How does the tapered pin come out?? Would it be a good idea to heat the pin or the flywheel with a torch to help remove both?? Chads
Mike S
11-04-2003 21:06:14
 Re: Re: Re: F-20 flywheel question in reply to ChadS, 11-04-2003 17:02:50
make a puller to pull the pin it should come out ok the hard part is the flywheel. I didnt want to put any heat on the flywheel I just made a strong puller.
