Oliver 990 GM diesel question
Jonathan
11-01-2003 14:11:13
whats the engine model number used in those "hot rod" machines?. Did the super 99 have the same engine?.
thanks in advance!
JD dozer mike
11-06-2003 18:13:44
 Re: Oliver 990 GM diesel question in reply to Jonathan, 11-01-2003 14:11:13
Any idea of the HP of the 2-53 and 2-71?
Lee W
11-01-2003 15:49:27
It is a GM 3-71, the super 99 used the same engine.
Jonathan
11-01-2003 16:22:45
 Re: Re: Oliver 990 GM diesel question in reply to Lee W, 11-01-2003 15:49:27
This is problably going to sound really stupid, but, does the 3 stand for 3 cyl. and 71 stands for 71 cubic inches per cylinder or am I way off.
Lee W
11-01-2003 18:52:42
 Re: Re: Re: Oliver 990 GM diesel question in reply to Jonathan, 11-01-2003 16:22:45
You are right the 3 is no of cyl,s and 71 is the cubic inches per cylinder.
Jonathan
11-01-2003 21:15:11
 Re: Re: Re: Re: Oliver 990 GM diesel question in reply to Lee W, 11-01-2003 18:52:42
how about the 353 Detroit, is that 3-53 and does that formula work on all the other Detroits, so like 453 would be a 4 cyl. with 53 cubic inches per cyl. or am I incorrect.
John
11-02-2003 06:40:49
 Re: Re: Re: Re: Re: Oliver 990 GM diesel question in reply to Jonathan, 11-01-2003 21:15:11
Yes on the 2-cycles the first digit is the number of cylinders ie 2,3,4,6 and the V type engines start out with the number of cylinders plus a V designation ie 6V, 8V, 12V etc and the second number is the cubic inches per cylinder
Jonathan
11-02-2003 07:24:06
 Re: Re: Re: Re: Re: Re: Oliver 990 GM diesel quest in reply to John, 11-02-2003 06:40:49
I had never heard the term "2 cycle" before when talking about diesel engines. I know a 2 cycle gas engine uses oil mixed in the gas for engine lubrication and doesn't have an oil pan full of oil. Do some diesel engines use the same syestem?.
Dale13
11-02-2003 11:24:01
 Re: Re: Re: Re: Re: Re: Re: Oliver 990 GM diesel q in reply to Jonathan, 11-02-2003 07:24:06
Detroits do have a base full of oil,intake is thru porting in cylinder wall not thru the base.
Hal
11-02-2003 20:51:03
 Re: Re: Re: Re: Re: Re: Re: Re: Oliver 990 GM dies in reply to Dale13, 11-02-2003 11:24:01
So is that why the Detroit 2-cycles have a Supercharger? It would seem that a 2-cycle design like this would never work without a supercharger. The supercharger would be required to force the air charge into the cylinders, unlike a conventional diesel where the downstroke of the piston causes a reduced pressure drawing the air in.
yep
11-03-2003 06:19:53
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Oliver 990 GM in reply to Hal, 11-02-2003 20:51:03
Yep, they've all got the supercharger for just that reason. Some have a turbo and that feeds the supercharger.
bindernut
11-06-2003 23:02:50
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Oliver 990 in reply to yep, 11-03-2003 06:19:53
The 53 71 & 92 series are all 2stroke. They have valves like a regular 4stroke, and seperate oil & fuel systems. The supercharger really doesn't force much air into the engine in stock form. It pasically just cleans out the cylinders. Lots of people have regeared them to push more air into the cylinders. But that involves custom gears & gets pricey.
Bindernut
josh
11-13-2003 06:08:47
 Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Oliver in reply to bindernut, 11-06-2003 23:02:50
how do you speed up the blower? It drives off the camshaft gear, so how do you change ratio?
slowsmoke
11-02-2003 06:37:00
That's the system, from a 253 to a 16v149
TimC
11-01-2003 18:51:09
Yes 3 x 71
buickanddeere
11-01-2003 16:53:38
The 3-71 is good for about 135 HP in a "N" four valve at 2300rpm for months at a time. That's without being over fueled or over reved too.
lw
11-04-2003 10:31:32
 Re: Re: Re: Re: Oliver 990 GM diesel question in reply to buickanddeere, 11-01-2003 16:53:38
trust me, a 3-71 is good for a lot more than 135 and when you wind them up to about 3600 its quite the show
bindernut
11-06-2003 23:12:49
 Re: Re: Re: Re: Re: Oliver 990 GM diesel question in reply to lw, 11-04-2003 10:31:32
I'm sure it would sound wicked. Just don't blow it up. My buddy witnessed one explode once from over reving. A piece of piston/rod put a nice 3" dent in a brand new Snap On tool box, & a another piece put a hole in a radiator. Needless to say that the shop owner was pretty ticked.
Also gotta watch the temp gqage. I've seen a lot of Detroits with cracked heads from overheating.
Bindernut
