Lamont don't put the Case out to pasture
MR Animal
10-29-2003 16:51:16
Lamont, you can pull that Case in the modern class. Our modern class is growing and you should do well in that class. Your Case runs and pulls well and we would miss the show you put on with it if you stop pulling it. See ya at Black Rock,AR pull. ANIMAL
Lamont
10-29-2003 19:09:30
 Re: Lamont don't put the Case out to pasture in reply to MR Animal, 10-29-2003 16:51:16
We'll probably pull it if the Modern class grows. We need to put the wide front back under it so it won't steer "BASSACKWARDS." My grandpa wants us to drop the 3 point down out from under the fuel tank so he can hook the field cultivator onto it. He says he needs it to work and wishes he'd never sold it dad. My grandpa is only 90 years old and says that 570 Case is not big enough to do all the work he needs to do. The 930 I guess will be semi-retired. See you at Black Rock. Have you checked out the track there?
Lamont
MR Animal
10-30-2003 05:00:21
 Re: Re: Lamont don't put the Case out to pasture in reply to Lamont, 10-29-2003 19:09:30
They have worked on the tracked all week and it well packed. I do not know if it will be as good as the Melbourne track, but it will be in good shape. See ya at the pull.
